Cant pick up any sat's
ARM
0 sat's greyed out. GPS puck not cracked, secure connection to the board plug as well.i want to be sure its the puck before i buy one .(or can it be something else?) Can i fly without it? if so what steps do i need to take to do that?
What are you flying? I can’t help in solving your satellite problem but you should be able to fly manually just fine without GPS. If you can manually start your motors and you are connected you can fly. But more Carefully.
I'm flying a phantom 2 vision plus V3. Please explain how I fly without GPS. The motors will not turn on.
I don’t know anything about that model but now that you’ve listed it I’m sure someone in the know can help. You may want to add the model to your description.
It would seem there is an issue with the GPS puck/module or the connections as it must be sensed present, at least, to allow motor start.
This is different than not receiving sats. such as a cracked antenna, being indoors, or other situation with no clear view of the sky.
I’m not aware of any way.
Sorry
On mine the motor's wouldn't start either when the GPS wasn't working once I replaced it it worked fine so it looks like you won't be able to fly it until the GPS is fixed.heres the link to where I got mine if you want to replace it, I don't know what else it could be unless the motherboard is cracked or something s wrong with the Nazarene it's used but a LOT cheaper then a new GPS.https://www.ebay.com/itm/DJI-Phantom-2-Vision-GPS-Module-V1-0-V2-0-V3-0-Part-P2V-11-BuyNOW-GetFAST-inv/112545915999?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D6b24605340dd4f6e919e916d39dd3636%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D112545915999%26itm%3D112545915999%26pg%3D2481888&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Ad69e2e30-b000-11e9-818c-74dbd1804bf9%7Cparentrq%3A30b5f0f016c0a9e423b9dfbbffffc115%7Ciid%3A1
DonT
