Cannot see P3A remote in Go App
I was checking some settings the other day when all of a sudden my DJI Go app will not connect to the remote. The aircraft does sync with the remote, but all I see in the Go App is "Disconnected" in gray!
It is green.
I know you said it was synched (I took that as linked) but it wasn't clear if it was actually connected. If you have a green light, obviously you are connected.
I would first try a different cable. I've never had that problem, but others have. Start there.
If you're certain it's not the cable, I have experienced "not connected" and turns out the start up procedure made a difference.
1) turn on remote
2) power up aircraft
3) connect device via cable
4) start the app
Credit to Mike Singer with Phantomhelp for this suggestion.
Reactions: tunadoctor
In case changing the cable and mobile device won't work, there's a diagram here:
Start with the blue box "RC diagnosis starts here".
I occasionally have this happen or I get black screen with DJI logo in centre.
I suspect it's due to my trying to get started in a rush !
My remedy is power down and then :
Power up tablet leaving on desktop and cable UNPLUGGED from tablet
Power up controller
Power up drone
Once I have drone stabilised and green light on controller
Plug cable into tablet and accept start GO.
If any step is rushed / changed .. I get the no go !!
Of course not all cables are suitable for android tablets and I had to go through a load before I found the one that worked. If I change tablet - I find again - I have to check which cable to work ...
So I have the same problem but the RC blinks red, the P3A blinks yellow. Not connecting. What's next? I'm going to find a troubleshoot matrix...
Also I bought this used, seller stated he uploaded new firmware on one but didn't get it on the other.
Can I and How could I reset to original firmware?
It's not possible to do a "factory reset" on your P3A. I used to see threads about roll-backs but I'm not sure it's actually possible. Do you know what firmware you're running?
First thing I would do is try re-linking the RC and the AC.
Reactions: Suntana
There are 'hacks' to do rollback .... because DJI removed the function ages ago ...
BUT I advise caution : I bricked my P3P using the hack that gets recc'd ....
Every FW change poses a risk.
No need to discuss it here, as @BoomStahl does not need a FW up/downgrade. Unless there's a big difference between AC and FC firmware version.
1. re-link
if that does not work:
2. check FW package versions
post them; if people answer these are not compatible, upgrade the older one. if no change after that:
3. check if all modules are responding within AC and FC
Try delete Go ... re-install ...
Seriously? When RC and AC are clearly not connected to each other?
I was posting based on the 'ORIGINAL' subject of this thread - lack of GO app connecting to RC.
Sorry but your question merits a SEPARATE thread instead of hijacking this one.
I didn't even noticed this is a stolen thread. "the same problem" is not the same at all.
Title of thread : "Cannot see P3A remote in Go App"
hcashmore11
