Can anybody help me with my gimbal problem (video sample)
D
DrewFlies
Guest
so from 1:52 to 1:56 in the video below. My gimbal horizon is off. But if you notice in the same clip sequence it sorta adjusts itself after 1:56. Then it has a kinda of wobble side to side. Also, in the part 1:26 is the same flight sequence and the horizon looks normal and fine. Why is it bouncing around like that? I calibrated it on flat surfaces and It seems to be normal in every other video I had down in the keys. Its even normal in the same clip sequence at some parts. Lost for idea. I don't know what to say or do.
It does sometimes seem to get confused if you yaw rather quickly, as in your example it will often slowly go back correct, - the Inspire does it too.
I suspect if there wasn't an ocean horizon it might have gone unnoticed!
That is correct. I only really notice it when theres an ocean horizon or really any horizons above 200 feet. In this specific clip I really only noticed when when there was an ocean horizon though.
jorge sanchez
