Camera tilt speed has slowed down
Nova Scotia , Canada
The camera tilt speed on my P3S has slowed down , I had to turn the gain up to 80 to get it to move , I used to have it set to 15 , this happened after I downgraded from 3.1.2 , RC has been recalibrated , any thoughts ?
What do you have the Gimbal Pitch Smoothness set to?
That setting should be fine.
Try calibrating your remote controller again. Make sure you're moving the gimbal wheel fully from top to bottom during the calibration process.
No. Relinking won't fix it though. You should try calibrating the remote controller in DJI GO.
solved : I downloaded the wrong version of GO when trying to get rid of 3.1.2 , I needed 3.0.1 , it has a setting of gimbal dial speed , separate from other gimbal settings , since my P3S was new on dec. 5th it was the first version of GO available for me , only other versions would be 3.1.1 and 3.1.2 .
loracle
