CAM Port Pinout
I know the CAM port on a Phantom 2 is 6 pins, but only 4 are used. Anybody know what the last 2 pins are for? I am hoping the audio is on those two pins, and I can route those to my transmitter.
Ed
Not sure what cable you are referring to. Do you mean the 8 pin cable from the H3-3D?
This is the port I am referring to. 6 pins, but only 4 are used. If anybody has the Pinouts for the H3-3D, that would also be helpful.
It seems likely that the other two ports are for audio + and -. Not sure if the gopro is audio connected though. Problem is, all you will hear will be the noise of the props, won't be much use to you.
jeetbuzz360
