Calibration
Hi guys, I've recently bought the pv2+ I do the s1 switch up and down to start the calibration I do the 360 turn and it's fine I then flip on edge and try the 360 vertical, for some reason it the flashes red and obviously isn't connected. When using lichi it tells me atti mode...... Please guys help if poss.
You typically need to do more than 360 degrees. Try that first.
The Atti. mode prompt is because you have the GPS antenna pointed horizontally during the second phase of compass cal.
