Calibration on litchi app
Since down loading ios 10. I have not been able to calibrate my p3A
Using litchi.... DJI ok
If you have a good calibration in GO you should be fine to fly with it. I'm not sure if your calibrating before every flight, unless you are travelling a long way between flying locations you are probably best to fly with your last known good calibration, I haven't calibrated my compass since May and haven't had an issue.
Not sure if you mean the IMU or the compass.
If you mean the compass, simply flick the switch from P to F 3 times very quickly and though there won't be any on screen indication of the calibration, the robot lady will tell you what to do and you can start the calibration!
Thanks for that info. I will try it. I normally calibrate the compass each time i fly the drone as i do travel some distance to locations. I use the litchi app quite a lot as the detail is greater than dji go.
Thanks again, its always great to receive assistance from members who have great knowledge of the drones.
Don carlos
