Calibrating controller help
Hi
Im trying to calibrate my controller time after time, but my A-range is way off and therefore I cannot fly... I haven't even been abke to fly once because of this and its getting really frustrating since I cannot seem to find the fix anywhere.
Please check screenshot.
http://postimg.org/image/z7r0onxon/
As you can see the value is way off, but all my sticks are centered and I've followed all instructions there is in the manual.
Very thankful for your help!
Have you tried to recalibrate everything using the NAZA Assistant? Try going to "Basic" then down to "R/C" then "Calibration" read the info on the left and then press start. I had to re-calibrate a couple of times, mostly because of my own failure to completely follow the Assistant messages, before everything finally was properly set. I notice in your image, there is a message box in the lower right. It is probably giving you a good idea of the problem.
I'm a newbie myself so I hope this helps you.
If you had a crash/hard landing at your last flight, you should:
1. open your Phantom
2. take out the red NAZA IMU, and knok it firmly on the table at the oposite direction of the crash.
3. I know it might sound strange, but as long as it works, its good.
