Boost
Two questions that maybe should be separate:
Is there a charger for the batteries that has a shorter charging time? I would think one has to start with a higher voltage and just taper it back quicker. Maybe there is an issue with how much power that battery can handle in a period of time.
The second question asks if there is a kit to boost the transmission signal from the RC controller? So far my range is acceptable, but I'd like to know if there are any options to increase the power output.
For which Phantom?
I was wondering if there is a way to increase the RC signal output in addition to concentrating the beam with a helical antenna.
I don't think so. Try the antennas. The distance it adds is most likely going to surpass your battery time.
Go for it. Let us know how you make out ;)
That looks like trooooooble :eek:
Added / This is why I say that .I didn't watch it but just saw enough from the bench to tell me to just
use what they sent me !! This came from the same group :
I noticed the burned bench, but that could have been from a small bonfire he used during the winter.
Xandian97
