Have a Phantom 2 and a ImmersionRC 600mW transmitter I'd like to pair up with a display. Are both fully compatible? Thoughts on which one before I pull the trigger on one?
I looked at all the monitors too and everything said Black Pearl.
s2kboy said:Black pearl with 600mw immersonic I get crazy range with this set up
rilot said:What's that mount you are using that connects to the neck strap point?
OI Photography said:rilot said:What's that mount you are using that connects to the neck strap point?
http://www.ebay.com/itm/FPV-Display-Mou ... 1c38ac8520
LeoS said:OI Photography said:rilot said:What's that mount you are using that connects to the neck strap point?
Thanks. I was about to hit 'buy it now', but where do you attach your straps with that thing installed?
OI Photography said:In either of the two holes next to each other on top of the balance arm. Take a look at it in the pic on the 1st page of the thread and you'll see those are the only places you can connect the strap once it's installed.
Fair warning though, I've seen mixed reports about that monitor mount, and this may be a better option when using either the Boscam or Black Pearl monitors: viewtopic.php?f=9&t=6239
