Black and white stabilizing balls (vibration absorbstion)
What are the differences between all the dampening balls that come with the gimbal? And what do they do different from eachother performance wise? I can't seem to find this info anywhere.
Re: Black and white stabilizing balls (vibration absorbstion
I think they are same except for your color preference choice
Sent from my SGH-T999 using Tapatalk
Stiffness. Not sure what order is what, but different stiffness to help combat vibration based on your setup.
So which balls are the smoothest. Stiff ones, soft ones, black ones, white ones? Is there any difference in ball choice between the P2+ and a modded P2 non-plus? My gimbal shows up tomorrow for my soon to me modded to fit P2. Need to know which ball is best.
I've always had good luck with the black ones. However, on my current build I'm having a little jello problem. First fix was to back off on the tightness of the zip ties through the dampeners but I'm still getting a little so am going to change to white.
For the P2 - and for two in a row - and for the P1 - the black ones seemed to work fine.
White dampers all around, no pins, no jello, two loose zip ties.
+1
I'm on white dampers, one pin at front one loose zip tie diagonally opposite at the back... Can't use the pin there anyway as the gimbal hits it in yaw. Great design that, dji.....
jorge sanchez
