Bit rate, FPS, ....
Going to fly my Drone today (P3A) for the 1st time since I received it back from repair. The footage usually comes out a bit juddery. Any advice what FPS I should pick? And when I edit it what bit rate should I choose? They are usually in thousands like 4000,6000,8000, etc... I am using filmora if that helps out
Thanks in advanced [emoji4]
Reactions: MotorCycle-Man
For smooth video I'd choose either 24 or 30fps if in the US. Your P3A is only capable of 40Mbps bit rate. Set your editing software to the same.
Most likely your video is jittery for other reasons, such as computer, software, etc. Make sure you are getting the video direct from the Phantom's SD card and it's being viewed after it was copied to your computer harddrive.
Reactions: Neon Euc
IF.......you have several video players......keep trying one that works best and plays the smoothest !.....i have four video players and the "GOM" video player works best for me...
Reactions: Neon Euc
Thanks guys. Appreciate the feedback and will do as suggested [emoji4]
thedrinklabsus
