Best propeller for smooth footage in Phantom v1
Hello, does anyone know which are best propellers to use with the phantom (1st version) for a smooth video footage? I don´t wan´t more time, not more lift, only smoother flight. Is there any better prop than the original ones?
Thank you very much!
I never thought balancing props would make a difference until I started building my own multicopters and every prop I bought was grossly unbalanced.
The good news is that most stock props are fairly well balanced. That being said... once I started balancing DJI props I noticed a marked difference! Make sure you balance them correctly including the hub.
I use the scotch tape method for the props and a hot glue gun for the hub.
Watch the video on flitetest.com on prop balancing. I tried using CA glue and zip kicker for the hubs and what a nightmare. hot glue took a little getting used to but it's so much easier to undo if you mess up.
Aeria
