- Joined
- Apr 1, 2018
- Messages
- 2
- Reaction score
- 1
- Age
- 27
All of the iPads from this list will work. For best results, buy the device with the fastest CPU you can afford. You can save some money by buying a refurbished/used device.What is the best ipad for the phantom 3 advanced?
Do you know if it matters if you get the 32GB model or is it necessary to get the 128GB modelAll of the iPads from this list will work. For best results, buy the device with the fastest CPU you can afford. You can save some money by buying a refurbished/used device.
Both of my iPad Minis are 16GB models and I haven't run out of space on them yet. I mostly only run DJI GO on them though. If you're going to run other apps that require lots of storage space, then it would make sense to use an iPad that has more available storage space.Do you know if it matters if you get the 32GB model or is it necessary to get the 128GB model
Thanks so much. My plan is to use this ipad exclusively for the drone.Both of my iPad Minis are 16GB models and I haven't run out of space on them yet. I mostly only run DJI GO on them though. If you're going to run other apps that require lots of storage space, then it would make sense to use an iPad that has more available storage space.
