- Joined
- Jan 18, 2017
- Messages
- 96
- Reaction score
- 4
- Age
- 41
if I get say a Verizon with cellular will it work if I don't add service and just use wifi
Since you're not familiar with them, it would be helpful to go check them out in a store so you can see the size of each tablet in person.I don't know much about Apple I am open to getting either a air or mini but not sure what one
Yes, you can use a hotspot to share the Internet connection and download the maps.But I could use hot spot with my phone correct
with the overheating dis you have green screen glitchThe only issue I've had with mini 2 is overheating in ambient temps above 90F. What kind of problems are you having?
Yes, with overheating there will be green garbage on the screen, and it gets worse and worse. When that happens you pretty much have to enable RTH, then take over control when you have VLOS. The RC doesn't overheat, it will control the craft just fine. Try flying the same mission from inside the car with the air conditioning running. That will confirm if it's heat related, but the Mini4 has better tolerance to heat since it has the A8 CPU. I think it will handle ambient temps of around 100F.with the overheating dis you have green screen glitch
My iPad Air 2 works in temps above 100F, that's what I'd suggest with a midrange budget. Make sure you fly without a cover if you're using a Mini4, which is also a good option, using the same A8 CPU.I am going to get a sin shade for it but it does seem to be a big problem with some people having the green screen issue
