battery update failed
SW UK
just received my p3p and done the latest FW update, all ok except for updating my 2 spare batteries, No 1 ok during the update of AC, No 2 went as it should but when I tried to do No 3 battery this is what the result shows, I formatted the sd card and reinstalled the FW again and tried it again, it still failed see result, so is my No 3 battery ok or not?
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
OK thanks Robin, I'll be in touch soon, nice vid by the way, that's the sort I want to make now I've got a decent quad
FYI, the above log is for your aircraft. A log is not created when firmware is installed on batteries. If your batteries ever need to be updated, you'll see a message displayed in DJI GO.
thanks for that Mike, so now no need to worry about it dropping out of the sky, cheers
BTW I used your info to update my new P3P it all went as you said, thanks
Nwbailey
