Battery repair
Thanks! You've got at least one badly bent internal clip but I would think that with a bit of careful manipulation and a bit of pressure it should all pop back together nicely again. I don't know P4 batteries well - but slacken off any casing screws slightly before commencing work.
As regards damage to the battery itself, with that kind of hit I'd treat it gently when flying for a while. If you can take the case off completely and do a visual inspection, then even better.
I would try to keep just the cover that locks into the craft and use it as a dust cover when storing your bird and dispose of the cells and electronics. (just a idea)
Reactions: RW8888 and N017RW
With lipo battery's its best to play it safe and junk it. You would be bummed if you crashed because you tried to re-use it. Phantom battery's are not cheap but they are cheaper than a new phantom.
Johnboy94
