battery monitors
ive seen several pics of peoples phantoms with digital gauges that display the battery levels. Any ideas on where to find these? do they weigh a lot, or steal a significant amount of power themselves? Do they usually just plug into the smaller unused terminals of the battery because I have a headlight on mine that already uses those.
I always just set a timer for about a minute less than the usefull flight time of the battery but I am afraid someday I will accidentally put in an uncharged battery, or have a weird discharge rate and then it just cuts out at the most inopportune time, like over water or on the edge of a cliff because murphy's law you know...
http://www.dronefly.com/ProductDetails. ... %2DChecker
http://www.hobbyking.com/hobbyking/stor ... VS_01.html
Those and most any other LiPo checker like that will connect to the balancing (small) plug on your batt, so you may need to get a splitter cable (or make one) to be able to use that at the same time as your light.
Another option is to add a Tx/Rx system that gives telemetry data such as battery level. This can easily be done for less than $100 and can be very valuable when the aircraft is too far away to see/hear the batt checker.
EDIT: Here's one more style: http://www.dslrpros.com/Products/tabid/ ... fault.aspx
Don carlos
