Battery error after shell replacement
Denmark
Hi guys.
I just replaced the shell on my P3P, after it got stress cracks.
When tested if everything still works, i get a battery error.
Everything works, and the battery is on. But i can´t turn on the propellers, as it say" Battery error, please contact DJI if issue persist after restart" (or something like that).
I really have no idea what i´ve done wrong, as the replacement was easy, and every piece went back to where it belongs. Just took some time.
I´ve tested all 3 batteries i have, and they all say "battery error".
ANY help would be very appreciated, as i´m almost giving up. :/
Thanks in advance.
Aiman
Given the same across 3 batts. this maybe an issue with the data pin interface(s).
Can you confirm proper connectivity?
Both at the battery and main PCB?
Reactions: Kolibri@Aiman
Can it still be an issue with the battery connector, when the drone turns on and everything seems to work ? Like the gimball moving, no issues with video etc .?
Absolutely. As N017RW noted above, those data pin connections talk to the battery circuit board. Do you get proper readings regarding battery in the DJI Go App?
Ah okay.
No, it´s in the DJI Go App, that i get the battery error. Shows battery at 0%.
I´m taking it apart again now.
Should be the 2 pin connector near the large black and white main battery connections. Maybe it is hiding under the MB?
It's open now (finally) ...
Forgot to connect this cable. Reconnected, tested before reassembling, and everything works now. Thanks guys. Really appreciate your help.
Exactly what it was. It was hiding, and I didn't notice.. Hehe
Thanks for the help !
Sweet!
Jerry P
