battery condition question
Western NY
I have a question on batteries. In Healthy drones, under the "power tab" I am seeing that cell one is showing problems it is always the cell that seems to be 24- 30 on the scale in the deviation portion. The part where it is reading a voltage difference of .01 volts between the cells. The final readout always shows green and says no major deviations. And cell one is still in the "green" on the dial. However cells 2-4 are all on the bottom of the meter with hardly any movement. Should I be concerned about this cell "dropping out". any thoughts?
-Bill
You should be ok with these deviations. Keep checking the capacity of the battery in mah and flight times. Also check that there is no bulge on the battery. A drop in the capacity indicates battery is getting old , a bulge on the battery case means time to discard.
Michello
