Battery charging systems
Charging at higher than recommended by the battery manufacturer will generate higher internal heats and reduce battery life. In an extreme case FIRE. Consider the news stories about "Hoverboards" in the last year or two. Lithium batteries in an enclosed space with limited cooling, not given time to even cool off before charging again because the kid (of whatever age...) is in a hurry to get back out there. The result is what has already been reported.... Physics is very unforgiving.
You can't exceed the the Charging rate of DJI batteries. The battery's on-board electronics regulate that.
The charger cited charges 3 at once not 'faster'. Marketing hype.
I got a similar one and I swear it cuts out the overall battery life more then the official one. So I don't use it anymore. Plus one of the leads always makes the battery stop and flash on the 3rd light.
