Battery cell voltages missing?
Gislingham, UK
Ok, so I'm going to throw this one out there.
Bearing in mind my P3PRO is currently missing a gimbal, although that shouldn't make any difference and has recently been crashed which might do.
The app shows the battery percentage and voltage in the top right corner, I'm assuming that's the lowest cell voltage
When looking at the battery information page, it shows the battery voltage in red, temperature, capacity, times charged.
However, it doesn't show the individual battery cell voltages. I can't work out why that is? It doesn't matter which battery is used either, I have 3 and all fail to display the cell voltages.
I can't say that the telemetry from the battery to the bird isn't working either because it's picking up the capacity, times charged and even the serial numbers of the battery and time to discharge.
Just refuses to show the cell voltages?
Any ideas?
Ok, so I've just fitted the replacement gimbal, seems like the gimbal has something to do with the reporting of battery cell voltages as the cell voltage displays have appeared again.
Bizarre!
Hello!
There was a similar situation on the phantom of the 3rd professional
Drone works without suspension and there are no other problems in work.
Was it possible to improve the situation?
