Attic mode
hi
I have phantom 3 professional some how is stuck in attic mode but on screen it shows gps mode I tried to switch from left hand side the mode it does change but not working on gps mode when I fly then press return home button in screen it just land there doesn’t come back to gps home, if someone can help that will be great.
Sorry the first pic was blur
That will happen if your inside a building, which by the pic seems like you are. If that's the case when you go outside it will get better satellite connection and should be GPS no problems
Thanks for replying neon
I was at the beach when I was flying to drop the bait when I press return home it was just dropping there so I had to bring it back manually to shore.
Even when it’s says gps mode but still having same issues it will not return home.
If you are closer than 20 meters to home or takeoff point it will land in current location.
Reactions: Oso
