From the reading I've done online, this looks like an issue that a few Phantom 4 Pro's are having. I made a quick video to show you how to fix the loose hub issue.
Let me know if this helped you out!
Awesome man. Mine was fine but I appreciate you bringing it up so it made me check it. Thanks Kman!From the reading I've done online, this looks like an issue that a few Phantom 4 Pro's are having. I made a quick video to show you how to fix the loose hub issue.
If you are bringing your drone down with full down stick you are gonna get some fluttering for sure. This is in the design of the motors to break up all the prop wash so bird won't get caught in it's own wash and fall out of the sky. If you look closely each motor has a slight tilt or cant to them. But if you come down a little slower you won't get it.Interestingly I have noticed some flutter to on rapid descent but I just checked my hubs on my P4P and they are rock solid. Don't suppose you have a video of the flutter? Maybe what you experienced was different.
I did this exact same thing. I think the old p4 hubs are solid because they also have the old style Springs underneath the plastic hub well the new style on the p4p it just sits flush on top of the motor and has nothing under it so even though the screws might be the same size. Maybe they should have been shorter I also noticed the screws on my old P4 have more Loctite on them ....the pre-made Loctite finish, which will help the screw stay in.
