Anti-Vibration gains?
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by skeeter, Sep 26, 2014.
  1. skeeter
    Kingman, AZ.
    If you've had good luck changing your P2 gains in an effort to control vibration and jello please post them here..
    Thanks!
  2. Wind_Shear
    Bump for interest. I have the same setup, everything mounted inside except the transmitter & camera/gimbal.
  3. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Stock gains, white balls and a Polar Pro ND. That's the only combo I've made work and it's not perfect. I still get occasional rolling shutter when the sun is high in the sky and I get heavy on the sticks.
    I've tried:
    Increasing yaw gain. Result: more rolling shutter.
    Using the stiffer grey balls. Result: more rolling shutter.
    Using the thin black balls. Result: vibration city. Why they even bother giving you these is beyond me.
    Checking the motors for imbalances, binding. Result: motors are balanced and free turning.
    Crudely checking props for balance. Result: props are pretty well balanced.
    Next steps:
    The GoPro 4 Black will be a big help in reducing rolling shutter. The imager is 2x faster.
    A 3 or 4 stop ND might not be a bad idea for midday shoots.
  4. skeeter
    Kingman, AZ.
    Thanks, Ianwood!
    Pretty much what I've observed with ball combinations...even with ear-plug-foam inside them...Have you mucked about with the vertical gain at all?
    Breezy days really wreak havoc on the 3D gimbal...didn't have much issue with the 2D in this regard...sigh..
  5. Geo74
    Next steps:
    A 3 or 4 stop ND might not be a bad idea for midday shoots.[/quote]
    Would you explain this ?
  6. ianwood
    Staff Member
    Lost Angeles
    Increasing the speed of the imager means there is less time for a movement to occur while the frame is being captured.
  7. skeeter
    Kingman, AZ.
Similar Threads - Anti Vibration gains Forum Date
Standard Anti vibration ball replacement? Phantom 3 Help Feb 9, 2016
P3S Gimbal Anti-Vibration Mount Standard/4k Discussion Jan 19, 2016
Professional What About A Carbon Fiber Anti-Vibration Gimbal Mounting Plate? Phantom 3 Help Dec 6, 2015
Anti Vibration mount / Jello Killer for P2 non Vision Phantom 2 Help Sep 23, 2014
Different anti-vibration balls? Phantom 2 Discussion Jul 30, 2014
