Anti interference board with H3-3D and P2 V3?
I am putting the original H3 3D gimbal that required an anti interference board on a Phantom 2 V3.
Do I stil6need to use the anti interference board? Does the V3 have a spot to install the board?
Thanks!
The interference isn't going to change just because you put the gimbal on a new P2. You can mount it the same way you had it on the other unit.
Thanks. There are some improvements to the V3. I thought maybe they might have built the anti interference into V3.
I don't think there are a whole lot if these gimbals out there which require the board so the latest circuit board may not have been designed with a place to attach the anti interference board.
I figured I'd need it but better ask and be safe than sorry.
None of the P2 non vision zenmuse H3-3D/H4-3D gimbals used the same interference board and it can be installed inside the shell.
You can also install the iOSD module inside if you have one.
