cavaleiro01 said:
Hopefully, I will be able to post my own test results here shortly, when the weather improves....
My set ups:
1) In the Vision
a) Full stock...
b) 2,4 GHz LHCP Pinwheel antenna, arriving shortly...
http://www.fpvlr.com/store/, $29,99
2) In the Wi-Fi repeater
a) Option 1 - 2.4 GHz 15dBi WIFI Signal Booster Router Wireless Networking Antenna SMA,
http://www.ebay.com/itm/330881041043?ss ... 1497.l2649, $8,91, shipping costs included
b) Option 2 - New Dual Band 2.4/5.8Ghz 9dBi RP-SMA High Gain Antenna,
http://www.ebay.com/itm/130858256856?ss ... 1497.l2649, $16,99, shipping costs included
c) Option 3 - 2.4GHz 7dBi Wireless WIFI Antenna Booster WLAN RP-SMA f PCI Card Modem Router T5,
http://www.ebay.com/itm/331071930394?ss ... 1497.l2649, $1,58
d) Option 4 - 2,4 GHz LHCP Parasitic Disc Helix,
http://www.fpvlr.com/store/, $84
3) In the TX controller
a) New Dual Band 2.4/5.8Ghz 9dBi RP-SMA High Gain Antenna,
http://www.ebay.com/itm/130858256856?ss ... 1497.l2649, $16,99, shipping costs included (I ordered two, so the shipping costs went down to half)
No amplifying and still working with the stock Wi-Fi repeater, so far.
Tests to be performed:
1-a) + 2-a) + 3-a)
1-a) + 2-b) + 3-a)
1-a) + 2-c) + 3-a)
1-a) + 2-d) + 3-a)
1-b) + 2-a) + 3-a)
1-b) + 2-b) + 3-a)
1-b) + 2-c) + 3-a)
1-b) + 2-d) + 3-a)
This is a lot of testing to be performed, already...
I will let you all know, as soon as I start getting some results.
So far, in a fully cleared area, I reached more than 1,000 m distance, control wise (never lost signal, the RTH was never triggered) and the Wi-Fi signal reached more than 600 m, with my stock P2V. This was done one month ago, before any modification...
I have the video, but didn't post it on Youtube, yet. As soon as I will, I will post its link here, also.
Took longer than expected, but finally got some good weather, here and made several tests, which you can find in the flytrex site (
http://www.flytrex.com/joao.d.paiva/).
The results were all a bit frustrating, to be honest, since I didn't get the results I was hoping for.
The range tests were all made in an area with no Wi-Fi interference at all and no buildings whatsoever, so, ideal to test for maximum range.
My Wi-Fi repeater cannot be working properly... my app goes black several times and I'm not able to put it back to working normally, no matter what I try. I'm charging the range extender all the time, with an external battery, but the picture still goes black. Sometimes, it keeps receiving data (range, height, etc), others, it completely stops.
As for the distances achieved, I am still trying different setups in the controller and in the Wi-Fi transmitter (the P2V is still stock), although I have to say I am not at all happy with the results I got from the modified setups, as I was able to perform better with my completely stock P2V in Jeddah, KSA, where I was able to reach more than 600m (2,000 ft) with Wi-Fi working 100% and more than 1,000 m (3,300 ft) with control in the Vision. At that time, I decided to back out before the return to home was triggered.
This time, I left the return home to be triggered every time, just to see how far I could actually go, so I will go back to the stock antenna. On the controller, I used a 9dBi Omni antenna, a panel 11dBi antenna and a clover leaf antenna, all of them with very similar results (from 700 m to 800 m, ie, 2,300 to 2,650 ft).
As for the Wi-Fi repeater, I tried using a 6dBi Omni antenna, a panel 8dBi antenna and a 15dBi Omni, also, but I was always loosing signal after 200-300m (700-1,000 ft), which is very poor. I kept one of the inside panels of the stock repeater working, but it didn't work out.
Waiting for my new Wi-Fi antennas, pinwheel for the P2V and a parasitic for the Wi-Fi repeater.
In the meantime, I will try the normal 2dBi 5.8 GHz antenna on the controller (similar to the stock one) and will go back to the two 2.4 GHz stock panel antennas on the Wi-Fi repeater, to see if I get the same range I was getting in KSA...
