Antenna Plugs (No more drilling holes!)
Hey guys, check out the new antenna plugs I've designed for the DJI P3 Adv / Pro, Inspire 1, and now the P4. This eliminates the need to drill holes for antenna modifications.
EDIT: WE ARE NO LONGER SELLING THE ANTENNA PLUGS. FOR THOSE OF YOU WHO PURCHASED THESE & WANT TO UPGRADE TO OUR CLEAN INSTALL KIT, PM ME YOUR ORDER NUMBER AND I'LL SELL YOU THE CLEAN INSTALL KIT MINUS WHAT YOU PAID FOR THESE ANTENNA PLUGS.
Nice. You should design one that allows for a continuous, longer cable to run from the controller plug-in to the antenna. Those connectors in between eat up something like .3 dB for each one. Maybe make it so the plug is cut down one side so the cable can be inserted in the side and when plugged into the hole it grabs it a bit?
I.can look into doing something like that. It would have to securely hold the cable in place so you don't accidentally disconnect it internally.
Hey guys, check out the new antenna plugs I've designed for the DJI P3 Adv / Pro, Inspire 1, and now the P4. This eliminates the need to drill holes for antenna modifications. Maxx UAV
I got the booster kit less the DBS panel antenna from Jake and here's my finished setup.. Lovin' it.. :-)
