Android App: "Phantom Vision Power" another booster!
N
Noël
Guest
I've had some time to kill today so I coded a small app to boost the power output from the Phantom Vision.
Basically this app will do the same as all the other "power" apps.
As the weather here is non flyable at the moment I've not been able to do outdoor tests, however I do notice a Wi-Fi signal improvement from the Vision after running the app.
Also note that this version is still in beta, and I would like to ask other Vision pilots to test it, and let me know if it did work, and/or what can be improved!
Things that I'm still going to add is a better verification/error checking, layout improvement and whatever I think is needed to make it better than the other apps..... :)
You can download Phantom Vision Power here: http://www.droidbin.com/p19ee8ilqvoe475l1ohj1oq6l973
Instructions:
1 - Turn on the Range Extender (and transmitter)
2 - Turn on the Phantom Vision.
3 - Make Wi-Fi connection with Android device.
4 - Run the app "Phantom Vision Power"
Done...
When turning off the kit, everything will be reset to it's default settings!
disclaimer: I'm not responsible for whatever happens when using this application!
Please fly safe!!!
