Aircraft disconnected and no image transmission signal issue
Hey everyone, so after many flight over the last few months i turn on my dji phantom 3 standard and it consistently says no image transmission signal issues followed by Aircraft disconnected and when i check the settings it says gimble disconnected, this is not true as the gamble is moving on start up as always so I'm not quite sure whats happened also the no image transmission signal issue then changes to Aircraft disconnected.
anyone had these issues, i've tried quite a few things checked the connection cables of gimble and looked for any damage to cables etc but nothing seems to be damaged, I've also reinstalled the app,checked the gimble is aligned properly with the motor and all seems to be correct. I'm kinda of at a lost any suggestion would be super helpful as ever pretty much tried everything. i almost feel like if i fix one issue it would fix the other issue.
