After RC update Noticed small LED
After I updated the RC -Noted the far right single White LED blinking. Is that normal?
Thanks in advance.
Assuming you completely charged your remote controller before installing the firmware, that light should not be blinking. Normally though, that means your battery is about 75% depleted. So, if you did not charge your remote controller beforehand, then that is probably the case.
Sorry -- I got that backward. If the white light on the right is blinking (and the left 3 are illuminated), that means the remote controller is 75-100% charged. What you're describing sounds normal.
Check the TXT file that was generated on your memory card to see if the installation was successful. Or, check the firmware version number in the About section of the DJI GO app.
Ah, then check the version in the app.
akinproplumbing
