Adjusting gimbal roll with right dial
After the few latest firmware updates, adjusting gimbal roll with the right dial + C1 doesn't seem to work. I get the green alignment cross, but the gimbal doesn't rotate as it should when I rotate the dial.
I have the regular P4P, and use an iPad Mini 2.
Have anyone else experience this or found a fix?
I know its weird now. If you keep really rolling it hard and quick sometimes it takes. But it's diff for sure. But that said, I think the crooked horizon line is much better than it used to be.
For me, it worked as intended until the last few updates, I don't know which one that broke it. Yeah, if I keep on rolling, it sometimes make an adjustment. To reliably correct the horizon, I now have to go into the menus again. Absolutely hate it.
I also get a help message when trying to adjust it. "The right dial is locked, press it lightly to activate" or something like that. If I do that, it just selects one of the exposure parameters (as it should), but it doesn't affect my ability to adjust gimbal roll. I guess DJI has added this message to help out beginners, and accidentally broke the gimbal adjustment at the same time.
I didn't upgrade my p4p to the latest firmware, but I think it's only one firmware behind the newest. Holding the right trigger + scrolling the wheel/dial still works 100% of the time for me. The horizon issue usually happens whens when the flights are long distance for me.
