A little help with Litchi
I'm trying to create a Mission in Litchi.
What I would like is for the drone to start by looking a POI #1 for 5 seconds, turn approx. 180 degrees and tilt the gimbal to -20 degrees, then, proceed with the rest of the Mission. I would like this to happen in the shown order.
I can get the drone to look at POI #1 but it will not stay for 5 seconds. It turns, waits 5 seconds tilts the gimbal past -20 degrees then comes back to -20 degrees and continues on the Mission. Everything goes fine once it starts on its way to waypoint #2.
Got any ideas or thoughts?
Thanks...
it won't actually focus on the POI if it's out of range of your controller. you have to program that in to the mission manually - don't try to use Focus POI. unless you are within range with your controller, but none of my missions are ever nearby - that's why i fly missions - cause they're way off.
billyboy02
