9 Inch Props on a Phantom V1.1.1 space between
Is this space between props normal? Its safe? I change the stock 8 inch self tightening to 9 inch DJI props, this is a Phantom V1.1.1 and I just want to make sure before flying.
Mine are 0.350 inches apart tip-to-tip. Yours look the same.
So yea, I would say OK.
Is there a difference in the P1 v P2 shells regarding major dimensions?
You know... besides vent holes, battery housing. etc.
So then P1, P2 pros are interchangeable.
Correct, all versions of the Phantom all the way back to the very first 1.0 are able to use DJI's 9443's props...although anything before 1.2 will have to use the non-self-tightening version.
You won't go back to the 8" after flying with 9" (DJI) props
Lets give them a try, I hope I get more flight time, also Im gonna try using this props with my new MadDog 2700 mAh Battery.
Michello
