yea!!!tizzl10 said:ok, so now I finally got it to stop shaking uncontrollably. took it up for a test flight and there are jitters. going to play around with the settings some more. any tips to smooth it out? im uploading a video now.
rfernandez said:did you guys get the dampener protectors basically all it is two washers and s screw the dampeners need to be pre compressed to eliminate the shaking .. the factory dampeners are to soft..
What's the link for the video?tizzl10 said:ok, so now I finally got it to stop shaking uncontrollably. took it up for a test flight and there are jitters. going to play around with the settings some more. any tips to smooth it out? im uploading a video now.
grochester said:What's the link for the video?tizzl10 said:ok, so now I finally got it to stop shaking uncontrollably. took it up for a test flight and there are jitters. going to play around with the settings some more. any tips to smooth it out? im uploading a video now.
SlackerATX said:I ordered the kit and the separate mount thinking they were different. Based on a comment from another user they are the same and the kit comes with the same mount they sell separately. At first glance they look different because the pic with the separate gimbal doesn't have the Velcro in the pic, but it does have the slits for the strap. That and sometimes they picture the mount upside down so it get confusing.
I ordered both and should be here Monday so we'll know for sure. I expect them to be the same.
DKDarkness said:TheFlyingSentinel said:
Yes, I posted that link in the MotorPixie section on saturday. I contacted Marcus who drew the thing, and you can download the source files from his homepage http://www.stoeckli.net
Seems to be a very nice guy, he might update the design to include a better IMU holder and move the controller to the back, so keep following his designs![]()
Noël said:Is that the battery sitting in the back?
what fm receiver do use with the beacon? what type battery do you use with the beacon? Weight including battery?Noël said:I hear you. Have had (till now) no escapes with my Flip FPV and P2V, but better sorry than safe!
I'm using a FMkit for my tracking.
It's way smaller, but also works way different than a GPS tracker (more info: http://fmtv.us/rf_beacon.html)
Anyway.. I guess that your design is balanced (CG) for using the tracker. So will It be fine if used without one?
urgno said:and from today they also have a new design for the camera holder![]()
http://www.taco-rc.com/servlet/the-38/3 ... ell/Detail
