2025 LATEST DJI GO 3 FCC Patch
I don't know if anyone will still working with DJI PHANTOM 3 series in 2025, but right now there is a fully functional FCC patch based on DJI GO 3.1.82, as shown in the screenshot
This is built from CN 3.1.82, 64-bit libraries, works on Android 16. The latest version on the EN website seems to be 3.1.80, and I'm not sure if some features like map work in another place
1) DJI GO version
2) Screenshot from analiti. You can also use this app to check WiFi freq, power, country code. A reliable method! Seeing is believing
3) Screenshot from DJI GO. In FCC mode, 2.4 GHz band has 11 channels
I've noticed that many download links from several years ago are no longer working, and I don't want to see that. So I'm trying out a more reliable hosting solution. Head over to Github, where you'll find the source code if you're curious like me
Welcome to the forum!
Thanks for the intel. :)👌
Rod ..
View attachment 126698View attachment 126699View attachment 126700
1) DJI GO version
I'm from Australia and I got given a phantom 3standard that had a broken radio and Imu calibration struck /death. The easy smack the Imu did not work for this nasty P3,but after a lot of effort and pain as I suffer from chronic pain I fix this thing without purchasing any parts for it. Completed 2 long range way point missions both complete signal loss pray 🙏it doesn't hit anyone hard mode. So right now I completed as best I could uplink antenna repair and about to test.. So I am very interested in the modded app, can I get the file please?
@Wakata sir
Where are you located in Australia?
"Completed 2 long range way point missions both complete signal loss"
Are you using Litchi?
What is this distance, when you loose signal?
BTW!! Don't mess with the firmware at this point.
It is not going to fix signal range.
Here is link of a web sight that has a lot of information.
Welcome to the forum!!
Rod ..
Reactions: Daniel NZDF
not sure if its the same thing but DJI GO/4 has a modded version built using NoLimitDronez app,you can also build one using the deejayeyemodder tool that is on github.
ive got both the GO and GO 4 somewhere on my NAS drive, they offer fake login, FCC mode etc etc
@Wakata sir
Rod ..
Hello,
@Wakata sir
Rod ..
Im in Western Australia, Perth.
Yes I'm using Litchi.
Signal loss was pretty much straight away as Antenna was damaged, outside wire sheath (-)ground was torn and almost completely separate bottom half to top. I repaired it best as I could manage. I checked the antenna tip and it looked to be correct length soldered point still solid. Im not sure if it's common practice but DJI cover the 5.8ghz tip with some heatshrink and add another metal antenna tube end situated upside-down, then heatshrink it together.. I think its to protect the live antenna tip😑 I found it strange as u have the plastic antenna tube that covers the lot for protection.
Reactions: RodPad
That took me longer than I like to admit to write, but I i should of just taken a picture 😑lol
Reactions: RodPad
