1/2 corrupt file? Plays, then stops - cannot import into editing sotware
OK, I've had my first experience with a partially bad file...
It is 5:33 minutes long and will play until 1:40 then stops on all my media players... and more importantly none of my video editing software will import the file because it is "corrupt" even though the first 1:40 appears to be OK and will play on all my media players (up to 1:40).
This was an important job so I really need to recover the rest of the file.
>I did not shut the Phantom down before stopping the recording.
>All other video files on the same flight are fine.
>I already tried putting the SD card back in and starting up the Phantom hoping for it to "heal" the file - nothing
>I have tried renaming the file, even changing it to a MOV file, same result
I've read many, many issues about an entire file being corrupt, this is a bit different, like I said, it will play until 1:40 out of a 5:33 clip.
I have also read many different opinions on repair software - I do not mind paying for it if I have to.
Suggestions, recommendations?
It may be worth trying a free data recovery program to see if that can find where the file has gone corrupt. If you google 'data recovery programs' you will find plenty on offer..one examplehttps://www.piriform.com/recuva
Unfortunately, cards don't last forever and it may be that yours has called time. If you don't have any luck with a free program, there are plenty of companies that specialise in data recovery, but they tend to be expensive!
I hope you get it sorted :(
Reactions: Mark The Droner
Thanks RockyDog.... I tried that one and one other but no good... I think because it starts to play the recovery software sees nothing wrong with it.... and the editing software sees it as corrupt.... I think I'm SOL... :-(
Perhaps try one of those simple file splitters rather than full blown editing software. Maybe if you're lucky you can split out the first 1:40 and then try a recovery tool on the corrupt remainder of the file. It's a stretch I know, but since you said it's important its worth a try at least.
You can also use VLC to save the good 1:40 if that is one of the media players that works for you with this file, but that will only save the good 1:40 and not actually split the file.
Good luck sir.
