You gotta rely on the tech....
Yeah I’m confused here as well. If you lost RC link (red LED on RC) and your failsafe is RTH it should always return home unless critical battery landing correct?
You can be safe without being able to see your craft IMO, as long as you can see the air space your craft is located. You'll always need LOS to have a good connection to control the craft, so you should always be able to see the air space the craft is in. Beyond 2500' I can't see my craft if I take my eye off of it, however I can hear and see other manned craft if they approach my airspace. If that happens, and it has, I simple go from my normal 150' AGL down to about 50' AGL. From there I locate the craft with the drone camera until it leaves my airspace. The noise of an aircraft (helicopter or plane) is audible for miles. At our altitudes the most likely encounter would be helicopters, and those have a distinct sound and generally move slower than small manned aircraft. There is no concern for jet aircraft if you're beyond the 5mi radius guideline for airports. You can see and hear a helicopter for miles and easily determine how to avoid conflict way before they arrive your flight area, assuming you're paying attention to your air space. That said, if one of those silent UFO's show up in my airspace suddenly, emerging from a worm hole, I'm screwed, but I yearn for that mishap to occur someday :p. Epic video potential. At least I know aliens won't be suing me in court for taking down their craft. :D
The more difficult situations are silent manned aircraft, like para-gliders and ultralights that aren't as loud, but are highly visible. This is where the assessment of all new flight areas is important, looking around the area to size up the surroundings, along with any potential air traffic. A couple weeks ago I was flying in an area that had para-gliders launching from a cliff on the Hawaiian coastline. They launched at about 300' MSL and flew at around 400 to 500' MSL. I watched them for about 30min to determine their flight patterns and then launched my P4P. I was no risk to them. Since they move quite the P4P is way more maneuverable than they were, I could easily evade conflict needed to avoid conflict, but I never had to evade them as it turned out. Simply by staying at lower altitudes (about 100' above the ocean) where they didn't fly, and keeping a good quarter mile distance away horizontally, there was no risk of conflict. I also had assistance of a spotter, keeping track of the para-gliders. Some pilots may not be comfortable with that, and that's good. If you aren't confident to fly safe you should stay grounded.
Reactions: With The Birds
No it won't because my antenna connection was the reason for the disconnect, the only reason it entered RTH was because the battery was running low
I understand that the modification to your antenna was what cause the mishap, I was just expounding on another users comment. video disconnects will terrify a user who doesnt know they could still be potentially connected to the craft, and able to manually RTH. I was just shedding a little light for the uninformed.
No biggie, and yes if it was just a video feed problem hitting the RTH button would work but this was something different , and to say it another wayas long as you have RTH set up in the menu for a low battery and the Home point was recorded for the flight you could shut the controller off or throw it in the lake and the copter would return home
Yes, and Im glad you had that parameter set and she came home. These are the good stories. What was the antenna mod if you don’t mind?
So do you think the RC disconnected at all then? Or was that part of your antenna hiccup? So it must have sit out there a mile and hovered until critical battery right? But if you did have RC connection for real it should have started RTH when you hit the button on your transmitter. Right?
Thats what I think it did it just hovered there in place until battery reached critical low and came back home I just charged the battery from that flight and it had about 25% remaining I believe my critical low battery is the default of 30%
"But if you did have RC connection for real it should have started RTH when you hit the button on your transmitter. Right?"
But I don't think the copter was able to receive my RTH request because of the broken antenna
fighterpilotlast
