I have had this P3 standard a little over a year and have had no issues what-so-ever until now.
The first hard landing I've ever had, about a 2 weeks ago... and I really can't comprehend how it was that hard of a landing. About 3 feet off the ground, I got nervous because I ended up too close to a building. Pulled down on the throttle fast, it bounced a little and then stopped, on a perfectly flat/smooth sidewalk. It didn't flip, it didn't hit anything. No plastic was damaged, cracked or broke. BUT the METAL yaw arm broke right above the 2 bottom screws on the side.
So I replaced it. The ribbon cable looks perfect.
After reassembling, the gimbal just goes crazy.
I took it apart again and checked all the connections, removed and re-seated each ribbon cable end.
I checked the position of the shaft of the camera to the the little circuit board (don't know the technical name) but made sure the 'D' of the shaft was perfectly horizontal with the camera, according to reading other posts and Youtube videos.
Put it back together again, no change.
I have run IMU calibration twice. No improvement at all.
I guess I'm going to be buying more parts.
Besides buying a complete gimbal/camera assembly, what should I replace first?
