- Joined
- Jul 13, 2015
- Messages
- 75
- Reaction score
- 43
- Age
- 54
I'm trying to find the original windsurfer site to buy from rather than the eBay knockoffs. Anyone have a link? I'd rather support the developer.
There are 3 different versions of David's windsurfers. Which one did you order? The largest one piece original version is hard to put on and take off, and is very directional, so you don't want to put it on until you actually need it. While putting it on during flight, you will likely lose signal for long enough to have the aircraft start RTH, because the antenna must be straight out to install it. Same with removing it for landing. In retrospect, I wish I had bought one of the other two versions that can be installed without flattening the antennas. Mine also required some dremmel shaving to fit, as it would not snap onto the antennas because it wasn't properly cut to fit.I bought one from Dynamic 3D Solutions. I think also its the original. Waiting its arrivel. I am really exited. I manly fly over water so must be fantastic.
I get that with my stock unmodded P3P without a windsurfer, but focussing the antenna signal with a windsurfer certainly improves the reliabilty, and probably adds a bit of extra range. Once you get out that far, though, battery capacity becomes more important than signal strength. You still need to make it back home, unless you "hot air balloon it" with a chase crew following behind to catch it!I fly with a few other P3 pilots (collectively known as the Phantom Menace) all using David's antenna booster. 15K' flights are common place.
You'll like it.
:harry
I now, but what I hope is dat my signal strenght is getting better also when I am closer to the RC. Mostley in urban aria i loose my signal within one mile.I am wondering if I can fly a little bit further so I can spy on my girlfriendA parabola is a parabola, no secret sauce here.
Anybody can produce a correct part, anybody can produce garbage.
EDIT: No disresepct to Dave W. BTW.
You can always try getting a little closer to your GF...I now, but what I hope is dat my signal strenght is getting better also when I am closer to the RC. Mostley in urban aria i loose my signal within one mile.I am wondering if I can fly a little bit further so I can spy on my girlfriend
The two piece version is also much easier to install and remove.Personally, I prefer the two piece version of David's windsurfer since it's much easier to fit in my P3's backpack.
Why don't you put your product on amazon?Hello all this is David Wettlaufer with dynamic 3d solutions. New user name on here.. long story but if you have any questions about my windsurfers or other items I would be glad to help.
I would think they are pretty similar, but I can vouch for David's Windsurfers. They fit well(not always the case with the eBay generic ones), arrived quickly, and I would rather pay a little extra and support a real guy with a name etc. I've got the smaller 'joined together' one piece ones. I quite like the fact that they don't totally cover the antennas, so (while I could be wrong and it's all psychological) I get the best of both worlds. ie I get a bit of the doughnut omni directional effect as well as the more focused and directional signal from the windsurfer. Tested (but not extensively) and in the same conditions and same place I get at least an extra km, and probably a lot more but I run out of bottle and common sense takes over.I'm trying to find the original windsurfer site to buy from rather than the eBay knockoffs. Anyone have a link? I'd rather support the developer.
dedstik linked your site in the 3rd post above.dynamic3dsoulations is the place for the original 3d printed windsurfers your looking for.
