Wind surfer tablet.
BVC
Sacramento, CA / Dener, CO
Has anyone tried putting a sheet of copper behind their tablet? I'm curious if that would help the signal at all maybe not be so directional like the clip on wind surfers..
Just tossing ideas while I starve.
It is the curvature of the windsurfers that concentrate the signal forward to more of a point. The stock antennas are already a flat panel antenna. You can pull the white sleeve off of the antennas to see what I am talking about.
Parabolic antenna - Wikipedia, the free encyclopedia
No, they are not. There is just a wire inside the plastic. They are simple vertical dipoles.
Here you go, just pull the plastic up off the base.
Enlarge the pictures to see more details. That is definitely not a simple wire.
You are welcome.
Nope, it's not a wire. It's a PC board.
Have a look at the pictures or pull your cover off. It's pretty easy to do.
It's not plastic by the way. If I scratch off some of the black coating, there is a copper trace there.
You are welcome.
I was expecting a wire also. No wonder the range is so good with the stock antenna.
And I'll try the copper backing and test that out. I'm curious more than anything..
Even if it helps a little it may be worth it my tablet is dedicated to flights so no loss of space or something to take off before storage..
jeetbuzz360
