Will turning vps off increase battery life
It's most likely a savings you won't notice. When flying outside, it's a great idea to keep VPS turned off. When on, it can sometimes cause erratic flight when flying close to the ground and/or when landing.
Taking off with VIPs on if on uneven no level ground has caused quad to flip to the side messing up props too.
It also can trigger dogs when it is on.
go into advanced settings the option on the bottom of the list always double check before flying that it is off as mine switched its self back on
Reactions: FASTFJR
I also think that you cant turn of the ultra sonic module, only the camera which is part of the vps system. As you might have noticed you will still hear the clicks from the ultrasonic module when you deactivate VPS.
DonT
