Will turning vps off increase battery life
Discussion in 'Pro/Adv Discussion' started by Wibble, Sep 13, 2015.
  1. Wibble
    Brecon Beacons Wales UK
    Just a thought as those ultrasonic transducers probably use a lot of current. They certainly make enough noise.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's most likely a savings you won't notice. When flying outside, it's a great idea to keep VPS turned off. When on, it can sometimes cause erratic flight when flying close to the ground and/or when landing.
  3. RoyVa
    Virginia
    Taking off with VIPs on if on uneven no level ground has caused quad to flip to the side messing up props too.
  4. Wibble
    My VPS is always on never seen a problem from it. Mind you I still haven't updated my P3 yet!
  5. 4wd
    4wd
    North York Moors
    I'm finding I still sometimes get the VPS error warning on the new firmware (You should land as soon as possible) This is usually when it's way high and should not be active - as before ignoring it works just fine.
    I think I'll turn it off again.
  6. Daninho
    Germany - Darmstadt
    For me its useless since i never fly indoors but it wont save much since its only active below a certain height
  7. Dronason
    Switzerland
    It also can trigger dogs when it is on.
  8. FASTFJR
    South East PA
    Never noticed any issues..........how do you turn it off?
  9. ghidora
    Bartlett
    there is a options in DJI Go app setting to turn it off.
  10. toorboy
    fife scotland uk
    go into advanced settings the option on the bottom of the list always double check before flying that it is off as mine switched its self back on
    FASTFJR likes this.
  11. Daninho
    Germany - Darmstadt
    I also think that you cant turn of the ultra sonic module, only the camera which is part of the vps system. As you might have noticed you will still hear the clicks from the ultrasonic module when you deactivate VPS.
  12. FASTFJR
    South East PA
Similar Threads - turning vps off Forum Date
Turning Off VPS On Phantom 4? Phantom 4 Discussion Jun 4, 2016
Turning Off VPS On Phantom 4? Phantom 4 Help Jun 4, 2016
Turning on and off VPS sensors Phantom 4 Discussion Mar 18, 2016
turning off VPS Phantom 3 Help Dec 25, 2015
Instead of returning home it lands! Pro/Adv Discussion Aug 7, 2017
