N017RW
Premium Pilot
For clarification: Are you suggesting doing away with manual mode, or are you saying the P3 has no manual mode? Personally, I would not want to own a drone that has no manual mode.
On the FAQ page when addressing the "P, A,F" on the Tx states:
(http://www.dji.com/product/phantom-3/faq)
This switch, called the Flight Mode Switch, allows you to toggle different flight modes:
P-mode, or Positioning mode, indicates that both GPS and the Vision Positioning System are active and your Phantom 3 will attempt to stabilize using both.
In A-mode, or Attitude mode, the aircraft does not use GPS or the Vision Positioning System. Only the barometer is used for stabilization. The aircraft can still return to the Home Point as long as a sufficient GPS signal is available.
F-mode, or Function mode, activates Intelligent Orientation Control (IOC) functionality. Refer to the IOC section in the Appendix of the User Manual.
By default, only P mode may be used. Refer to your user manual for instructions on unlocking the other modes.
This seems to imply no Manual mode and I too took it to mean there is none.
Seems one must wait to be sure.
