Wifi booster... Worth it ??
this would work for the control signal only as the wifi signal is 2.4Ghz
You recently started another thread about CE vs FCC power levels, so clearly you want more range. Personally, I would re-consider Icarus (I know it did not work for you the first time you tried, but it worked for many people, myself included) or try Magic Power, and if that's not enough, go for better antennas before thinking at amps. Lots of positive comments about the DBS here, but if I had to do it I'd go for the Alphas, very clean setup: DIY Antenna Modification - RANGE TEST (14,180 FEET) with DJI Phantom 3 Standard.
Reactions: Flying Mackerel
Digitdrew
