Professional white rubber pads on gimbal
the clear plastic spikes that go through the centre of the white rubber padds, should there be one on each
Edmonton Alberta
You only need two Anti Drop Pins in the gimbal, where as the four Vibration Dampers keep an even amount of pressure on each of the four corners.
RedHotPoker
Got mine back after crash repair at Dji and they sent it back with no drop pins. I installed automotive zip ties and just left enough slack for it to work like drop pins and if you crash your camera won't go bouncing down the road.
New Threads
drccam1
