Where is the Serial Number on the Phantom 3 Pro?
Hello I have checked the bottom of the drone and cannot find the sticker. Is there any other way to check for a serial number? I do not have the box.
You can find the serial number in any of your TXT flight logs. Use the TXT-to-CSV Log Converter to convert the TXT file to a CSV file. You'll find the serial number in the "DETAILS.aircraftSnBytes" column of the CSV file.
Hello, I just tried to load my txt but it does not seem to want to open, heres the file.
  • DJIFlightRecord_2017-07-29_[18-49-58].txt
I was able to open it, but the serial number is not in the CSV file. It looks like that version of DJI GO does not log the aircraft serial number in the TXT flight log.
Take a look in one of your DAT flight logs. You can find instructions for locating the DAT flight logs here.
The serial number that gets recorded in the .DAT is the serial number of the Master Controller. For my Mavic the serial number shown on the body is not the same as the MC serial number. I suspect the same is true for the P3.
If you're using DatCon to find the MC serial number on a P3 it will be at the very end of the configLog stream.
