What kind of white glue White adhesive do I use
What kind of white glue do I use That covers the motor wires On the Circuit circuit board and it also holds The antenna in to the landing legs Phantom three standard thanks I hair of threbond but that is not available around here
Go for silicone over hot melt. Hot melt can get brittle and let go with vibration. I wouldn't be fussy about trusting to get white, they all stick the same.
Be careful with silicone. Some release acetic acid (vinegar smell) as they cure. If you can find some designated for electronics that would be best. Otherwise, use sparingly, try to avoid components and the metal paths on the board and ventilate well until cured.
Reactions: mdowney58
tpren3
