adanac said:Flying P2/H3-3D and encountered jello for the first time. It was bright daylight. I normally shoot 1080 60fps - would changing my frame rate reduce jello? I don't get it when it's not so bright out.
wkf94025 said:Get an ND filter such as PolarPro. This topic is covered heavily on RCGroups.com.
Kelly
BMEWS said:adanac said:Flying P2/H3-3D and encountered jello for the first time. It was bright daylight. I normally shoot 1080 60fps - would changing my frame rate reduce jello? I don't get it when it's not so bright out.
are you sure it's jello and not prop shadow? Post a video of it.
Bmews
d4ddyo said:what's the lightest nd filter out there?
d4ddyo said:d4ddyo said:what's the lightest nd filter out there?
Well how is that off topic. Someone reccomend a ND filter and even brand. I'm looking into their advice but want lighter.
adanac said:You win - I remember you from another thread - you're just going to tr--l it mercilessly till moderators have to intervene. This thread is now about which ND is the lightest.
adanac said:Kelly - great to know it's on RC Groups. Since I posted about it here let's discuss. Kindly explain the reason for an ND filter. Thank you!
Kelly
wkf94025 said:adanac said:Kelly - great to know it's on RC Groups. Since I posted about it here let's discuss. Kindly explain the reason for an ND filter. Thank you!
Kelly
The ND filter reduces the amount of light the sensor sees, slowing down the shutter rate. The H3-3D topic on rcgroups has pages and pages of discussion on filters, balancing them, and other anti-jello strategies.
adanac said:In any case, this thread is no longer about jello but about what filter is the lightest.
adanac said:This thread started about about jello but one of our forum dum dums decided he wanted it to be about something else. So, this thread is now about the lightest ND filter.
britchris1 said:This is the lightest option: http://peauproductions.com/store/index. ... cts_id=683
Fits inside the gopro protective lens cover
This is a close second: http://ragecams.com/shop/filter-lens-gl ... p-622.html
I use the polar pro ND filter, it works great if you use a couple of qtrs to balance out the weight
