What happened now?? Installed "better" wires to dbs
I just can't find another reason for this than these outer blue wires..
These work just fine with other people so I just got bad wires this time :/
...that can't be ruled out completely, however, to have the Same Issues with two diff sets..??, try
chg'g channels, try Chl14, see what happens, jus for grins.. then remove the dbs antenna, and try
it with ANY other antenna.. didn't go back in time, but if you're using one of the common, popular
boosters out there, remember the the Receive Gain...
IIIDaemon
www.GasRecovery.net
You putting them on right? They are male end and female end.. just had to ask. Sorry if out of line, with the twin 90° and hard to see pins it's easy to get them wrong..
I had them right.. I understand that female to female, but male to male? Isn't that impossible because of the pins?
Yes just watch the pins. Pin can't go to pin, has to go to hole. Make sure each cable has a pin end and a hole end and that the pit hasn't been smashed down by another pin.
